I'm in the middle of a repair project on a fiberglass canoe. At both ends, the canoe is "boxed" in (see pics). Both ends were experiencing rot. Both ends also were filled with foam. It appears that the foam was blown in, as there are holes in the tip and at the transom.
Would the spray-in foam insulation that you buy to use in your house work in this situation. Or would it expand too far and possibly do damage? (I don't want to reuse as both ends were damaged..not to mention bugs)
Front:
Rear:
After removal and sanding:
Thanks!
Front:
Rear:
Thanks!
