FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
85 3.7 liter mercruiser, goes into gear fine but when i drop the throttle the engine sounds like it spins out of gear. if i back out and go slow it seems to be fine.i had the prop checked out and i even put a spare prop on and it did the same thing. could my shift rod not be engaged far enough? i had the linkage ajusted and the mech. said that it was as far as he could adjust it.
with the boat out of the water and engine OFF, put the drive into FWD gear. go to prop and rotate counterclockwise. the prop should lock and not turn at all
if it does there is an issue with the engine coupler or drive internals
If the spare prop did the same thing, you may have a spun coupler. The rubber holding the splined shaft has come loose from splined hub.
When this happen, can you smell burned rubber?
