speedometer
walla2
what controls the speedometer on a 1996 reinell 184 brxl, 4.3l, alpha one
WD40.1
Re: speedometer
There's a hole in the front of the drive with a tube connected to it that runs into the boat.
Problem is a coupling can come loose leaving the tube disconnected.
(I've had to reconnect the one on ours a couple of times)
Look for that coupling on the front of the outdrive in the vicinity of where the lower unit connects to the upper housing.
I'll see if I can find a picture.
EDIT
See 0:50-1:00 in this video:
http://youtu.be/w3O63YTOhn8
From the following thread:
http://forums.iboats.com/showthread.php?t=559197
