I'm new to this so I'm hoping to share my restoration effort and maybe get a little advice along the way...
I have an older SmokerCraft Canadian 12 aluminum boat. It floats and has a very minor leak, was painted at some point and has some filler here and there. I decided to strip off the paint and give it a fresh look, tighten some rivets and reseal the hull.
I've been using an angle grinder with a steel brush attachment to remove the old paint. It's a slow process but works well. Some areas I'm heating with a blow torch and scraping, but I still need to use the grinder for the undercoat. The steel brush does wear down the rivet heads a bit but they're intact.
I'm going to repaint the inside after and put some new seats in it. I think the styrofoam needs to be replaced under one of the seats also. I've got an older 7.5 hp Honda for the boat.
I'm rather nervous about this project because I doubt the boat will end up watertight, but it's worth a try. I have no problem dumping it and getting another boat if necessary, but it would be a real shame to waste a good old boat like this.
