Slow to go in gear
degoude
135 Mercury, 6 cyl, 84. Shifts to reverse fine. When I shift to forward, it doesn't want to go in gear. The gears grind before it finally shifts to forward. Is there an adjustment thagt I can make without taking lower unit apart?
Thanks!
Laddies
Banned
Re: Slow to go in gear
Remove the cowl and the bottom cable is the shift cable shorten it by turning the barrel end 3 or 4 turns then try the shift again, it that point you will probably have to fine tune the adjustment again
degoude
Thanks for reply. I'll have to wait till I get my tilt problem straitened out to make this adjustment. Boating is always an adventure.
degoude
Thanks Laddies. I was able to get my motor down and make this adjustment. Your info was a great help!
