Shift Cable Question
Adam76
I'm going to be changing my bellows this weekend and while I have to pull out the shift cable to put a new shift cable bellows on what should I be looking for on the shift cable to see if it needs to be replaced. Thanks
Fishermark
Re: Shift Cable Question
You would want to look at your old one for any signs of binding or wear.... but if there is any doubt at all, I would suggest replacing it. If you do, most suggest you go with the OEM cable as it is a better quality than the aftermarket.
Ayuh,.... Yer Already there, ya oughta be Replacin' It too...
cr2k
shinny spots along the wire show where it is wearing.
