Shift bellows
rickasbury
Master Chief Petty Officer
Thought I would provide an update- I was able to get the cable out with little problem...the new/old boot I had a heck of a time getting off and their are pieces stuck as it tore getting it off so clean up is slowing me down. My boat is a Rinker 270 and has a 9' beam so compared to most boats I've looked at, much more room to work than most. The exhaust bellows is pulled off but even then, cleaning the surfaces up is a challange!
When I pulled the transom before I did not know about the heat shield material and got it all jammed up in the transom trying to get it out- eventually took a drill to it from the stern and managed to remove enough material to finally get the cable out but it was an maess- reason I bring it up I did not notice that there was what looks a guide that goes into the transom for the cable to ride as it moves with the trim- don't have one but will replace when I pull the drive next year to check the alignment.
So as I also mentioned, had a heck of a time getting the stupid bellows to stay on- eventually the solution was the rubber got so tacky from the acetone cleaning off the failed attempts at gluing it, it stuck to the metal and quit pulling off. I don't recall the brand of adhesive I used but it was not Merc and that has been suggested and purchased for this go around. Would that acetone have broken down the rubber and that's what caused it to fail? That boot had been on there only a few months. Anyway, my actual question is once I glue it on and put the clamp on it, how long before it is fully cured and when can I start yanking on it to make sure it's going to hold?
Rick Stephens
Doesn't take very long for rubber cements to dry. A couple hours and it is as dry as it's gonna get. The clamp should do most all of the work anyway.
rickasbury
Well, got it back together, right in the middle of a hail storm! We don't get those in FL often and this was golf ball size...never seen hail that large here......so was getting the clamp on and the darn thing is walking off....so I stated feeling around the bellows to see that it is seated properly and find that it is not. On the left side, it;s not quite all the way bottomed out.....so, after pondering I thought it best to pull it off and start over. Pulled the clamp off and went to yanking, it ain't coming off- so do I run with it the way it is and see if there is a problem? At least I know how to do it if it does pull off?? Ugh!
rickasbury
nah...don't think it would sink but sure need to resolve it. I could not pull the bellows off and I was yanking on it hard so that merc bellows adhesive is really working good...but the dang clamp will not stay on....I had it all snugged on there and when I came out this am to finish it had slipped off like it worked it's way off!
