OK guys, thanks so much for the help but you pretty much just blew the top of my head off...so I did a recent repair that Dodge, bt doctur and chris really helped me through that involved pulling my motor, transom assy, redoing the transom asy including new bearing and bellows and putting all this back together. I am not a mechanic and had never attempted anything like this on a boat but the point being, I had so much going on I don't remember much about this shift cable that I did replace. As soon as I get the new bellows I'll bring the boat home but Lord, I'm kind of lost. So if you will bear with me....so I get that the end of the cable that goes into the outdrive has a part on it that will not go through the boot and it has to be threaded in from the front end of the cable.....I thought through this whole process of explanation, I was pulling the core out of the casing as all the undesirable parts are on the cable not the casing.I don't recall how then engine end of the cable attaches but assumed it will pull out through the casing from outside the transom. If I understand what your saying, I'm pulling the casing out and leaving the core? And when I pull the casing out, attach something to it so I can pull it back through? I have my cable looped around the exhaust per the Merc manual with the heat shield and everything on it but I guess there are no tight bends there or it would not shift properely...and if I'm pulling the casing through, it's not going to go over what ever is attached to the core at that end of the cable at the out drive...I'm not getting this at all I'm afraid!.
