boater1234
Master Chief Petty Officer
- Jan 6, 2010
- 869
I am getting ready to paint up my outboard and wanted to know what would be better on it,zinc chromate or self etching primer?Which will protect better as well as giving the paint a better surface to stick to?
I have done tons of research the last few days and it's like 50/50 on all the sites i went on.What i did is sand down the whole lower unit to bare metal,i have read to use 50/50 water and vinegar for a better stick to begin with.I just recently painted the whole motor but put it on to thick and she peeled like an orange.This was my first time and i figured more was better but was i way wrong.I think i have the paint method down now as i think i was just in to much of a rush.
But now the thing is what primer to use on the bare metal and why?I have the good industrial yellow zinc chromate from moeller and i also have dupli colors self etching primer,so i have both to use.On the can of zinc chromate there is no drying times or recoat times so if i went that route what is the amount of time i should wait for it to be perfect to paint over?Should i sand it also?I'm painting a 15hp merc.I have the factory phantom black paint also.It was cheap at $6.50 a can so i got it for less then any other black i found.I want to do this right this time as i have spent tons of hours sanding and don't want to screw this up again.
Above the cavitation plate came out ok so i just sanded it down with 1000 grit paper to get any runs or minor bad spots out.I need to put one coat of paint on that,but like i said the main concern is the lower unit.I also wanted to know if clear coating is worth the trouble as all the sites were 50/50 on that also?The phantom paint is a high gloss so i would guess it would be a waste.Thanks for any info on the primer.
