Second Braking Axle Hydraulics
BRICH1260
I`m working on adding a second set of disc brakes to my trailers back axle. The front axle is already disc braked. I have looked into purchasing calipers and rotors and that part seems pretty straightforward on adding to the rear axle. My question is how are the hydraulic lines ran to the new calipers. Are the back calipers fed from a jumper line from the front caliper on each side or are they fed by a " 1 into 4" Tee that I would need to purchase and install replacing the current "1 into 2" Tee split from the main hydraulic supply line? Any help would be appreciated.
Re: Second Braking Axle Hydraulics
Ayuh,... Just "T" it ahead of the "T" there now, 'n then "T" it again on the rear axle...
Make the connection into the rear axle "tee" with a flex line just as is done with the front axle feed.
Bamaman1
See ChampionTrailers.com for complete explanations of everything about trailers. And, they sell all the parts.
BRICH1260
Seems to me that finding a "1 into 4" block would be the easiest solution, if they even make such a thing. That way I could split to the four calipers from the main "trunk line" at one junction. Does anybody know if they make such a device?
Ayuh,... That'll require more hoses, 'n joints...
The other way, ya only need 1 hose for each axle...
BRICH1260
Yea, your probably right. Finding two "T"`s would be easier than the 1 to 4 block, I described above.
Ayuh,... yer local Napa, or 'bout any other parts house oughta be able to hook ya up...
