TBarCYa
Thread starter- Joined
- Apr 13, 2005
- 781
We took the 1971 Concorde out of the water yesterday and are starting to assess the things we need to tackle in the off-season. Sealing and waterproofing is around the top of the list so the questions begin. I'm sorry but I know that this must have been covered but searching came up with some very specific results and also some very vague results, none of which seemed to answer these specific questions...
Rubrail and windows. there currently appears to be a flexible sealant around the rubrail and windows that we will be replacing. Would it be acceptable to use silicone for this or is there something more appropriate? i was thinking 3m 4000UV but I'm not sure how it will work to seal a window unless the window is removed and reinstalled so maybe LifeCaulk would be a better solution?
Bolts. I'm planning to use 4200 for the cleats, anchor holder and everything else that is thru-bolted. When I remove the exhaust flanges to seal them, I plan to use 5200 on those since they're below the waterline (sometimes) and once sealed shouldn't have to be removed.
Now the big question... *IF* we decide to paint the boat rather than just compound/wax, would it be be best to remove all caulking then recaulk AFTER painting or apply the caulk to the bare gelcoat and paint after? Or doesn't it matter?
Any help is appreciated.
