78Galaxy
Thread starter- Joined
- Jun 18, 2008
- 35
Hey all-
I am restoring a 1978 Galaxy 18' bowrider. I am putting all new hardware on it, but I've run into a hitch. I cannot remove the screws.
Here's what seems to be the problem;
The screws are secured under the fiberglass by nuts that are absolutely rusted solid. What's worse is that I cannot reach most of the nuts at all. Since I managed to remove the hardware without removing the screws (the 30-year-old galvanized hardware literally crumbled away under hand-pressure), there is some 'play' in the screws. I.e., I there is about a half-inch or so of each screw that protrudes from the fiberglass.
How can I removed the screws? I've thought about perhaps sawing the heads of the screws off and letting them drop into the hull, or somehow drilling them out. Any thoughts?
James
P.S. - I'll post pictures of it if needed after I get the boat back from its tune-up.
James
