Starcraft5834
Thread starter- Joined
- Jun 2, 2013
- 1,677
If you could choose between a 8.6 ft Shakespear Ugly Stik med action, or a Daiwa 9.6 ft medium action, with similar 8-20lb test rated rods,, which would you choose??
Salmon River in Pulaski NY is location,, the rod is more important in my view.. had (2) 10.6 ft Daiwa's snap in half in my hands.. before the line snapped.
:facepalm: It really suggests a serious look at the drag.Breaking two.......suggest you stick with Ugly Stiks
I can count the number of rods I've seen fail becouse of a drag failure on one hand. The vast majority of failures are operator error.....aka high sticking:facepalm: It really suggests a serious look at the drag.
Tom B.
(LongLine)
As a custom rod builder I cringe when I see someone using a Ugly Stik but...... there are those that I highly recommend them too.
The tips are too light and the action is way to slow. A progressive or fast action blank would be more enjoyable to fishThey can make a fine trolling rod,..................
Any ugly Stik is a great rod if you're concerned about running over it with your rig,they are practically indestructible
There is a new one out. Saw it on one of the cable tv fishing channels a couple of times. Wife takes his rod and put in the trash compactor. He gets it out and goes fishing.Remember those Ugly Stick commercials from the 80's, where the guy would bend the rod tip to the butt?... :suspicious:
Yes, for trolling... Use #80 Power Pro with 6-18', #80 mono leaders. 2.5 - 3.0 mph trolling speed, drags at max.~#22-25 lbs. Holes are not a problem...leverage and getting a 10/0, barbless hook to stick in bone is... If you've ever seen a #30-50 fast action blank bent almost to the butt while in the holder, you'd understand.For trolling???
I don't like a fast action rod for trolling,...
I use power pro line with a 20 foot mono leader and the softer rod helps keep the hook from wearing a bigger hole causing the fish to come unbuttoned,...
