torsion axles on these vs a spring axle, yes they ride better but the physics of a torsion axle mount puts all the stress on one section of the frame vs springs that spread it out over 2 mounts. If the frame is marginal, you can guess what will happen.
That looks very strong. Researched my roof and the little info I found it sounds like I gave 5" wood trusses. The rest of the frame construction is aluminum. Of all places not to cheapen construction, the roof should be high on the list...Aluminum stampings would have been lighter and about the same price, with a higher load capacity....
I know they make them because you can buy the replacements.
and you can find them with a google search. (this one is aluminum tube weldment)
I also have found fiberglass and injection molded reinforced plastic.
Yes and no.I get plumbing and electrical issues..... seriously, have you ever met an Amish plumber or electrician?
However lack of sealing of roof racks, using zinc plated hardware vs stainless
WTF ...RVs are built worse than 80s bayliners
If you want true quality, buy an Airstream. But it will cost about 3x what a comparable model costs. You get what you pay for.
My friend's Rockwood Mini Lite that is not very old and has torsion axles...bent frame! I will never buy a trailer with a Lippert frame. His trailer is basically worthless unless it's parked somewhere to never move again.They make it "look" good on the outside but the inside not so much.
I also don't like the use of torsion axles on these vs a spring axle, yes they ride better but the physics of a torsion axle mount puts all the stress on one section of the frame vs springs that spread it out over 2 mounts. If the frame is marginal, you can guess what will happen.
Trailer Axle Leaf Springs vs Torsion Axles – The Engineering
How to choose a Trailer Axle? Should it be Leaf Springs, or a Torsion Axle for your Trailer? Here we look at the Engineering in the choice.mechanicalelements.com
I'm parked under the oak for shade. Those are the shadows of the leaves . There is a leaf or two in the glue..... And a love bug or two.... will be there in 20 years from nowIs all that black stuff debris or just shadow.
No.you gonna OTF that?
Yep, It's clearly a shadow when I see it on my laptop. I really need to stop using the phone to look at pictures. I'll be glad when we get this finished up and back to the fiat. LOLI'm parked under the oak for shade. Those are the shadows of the leaves . There is a leaf or two in the glue..... And a love bug or two.... will be there in 20 years from now
