rust-o-leum marine top coat
rcl700
has anyone used the rust - o leum marine top deck paint??
thoughts on this stuff?
i found it for 8.99 a ct.+ shipping is this stuff any good for fiberglass?:rolleyes:
mtduckhunter
Re: rust-o-leum marine top coat
ive never herd of it, i would like to know more about it also and see some colors.
wca_tim
I played with some a bit and posted something about it somewhere on here a few weeks ago. It applied a little like interlux brightsides and used the same thinner base and I believe similar chemistry. it wasn't quite as glossy and was perhaps a little softer even after a few weeks cure time. Not bad for something you can buy at lowes for 10 bucks a quart. Although, like the brightsides and even a little worse, there's not comparison with any of the two compoinent auto or marine urethanes or even epoxy based systems. I was disappointed by how easily it scratched...
tashasdaddy
i have been using regular oil base Rustoleum for years on boats, hulls, top side, decks. this boat is total rustoleum. even used Rustoleum spray, to change color of bimini.
TommyA
tashasdaddy you sprayed the canvas with Rustoleum with good results? I really am fond of the choice of colors you used.;)
rcl700
do you think that there is any diffrence in the standard to the marine top coat? how does the standard hold up to uv rays?
who offen do you repaint? thanks for the fast replys!!!:)
tashasdaddy
it holds up well, i have not had to repaint. yes i sprayed the top with spray rustoleum. i have sprayed many things with it, you would never know. i have sprayed dirty gray carpet with it. do it lightly in the hot sun, dries quickly, covers the nasty stuff in boat carpet.
Pam C
can this be used on my Cobia? Are there any tips on "how to" ? I do not have chaulk buid up. Just faded out. I know I can not get pea green, but if I chose to change, could I use this product?
Pam
tashasdaddy
yes, Pam, i answered in your thread. http://forums.iboats.com/showthread.php?t=249055
you may experiment mixing the forest green and some yellow, maybe a little white. to get your own color. just mix enough to do it all. HD and Lowes sell empty paint cans. to store the mix.
Pam C
Would this work on the vinyl bimini
Bruce San
Tasha's Daddy, I know I'm replying to a rather old post but, How's that rustoleum holding up on the canvas? I have a t-top that is in pretty good condition but the canvas leaks like a sun of a gun. I was thinking about painting it but......
tashasdaddy
it has faded a little in the FL sun, but another can will have it looking like new. light coats, in the sun when you paint it. drys instantly, then you can recoat, it will look splotchy, until it dries.
rtpassini
this is just regular rustoleum rattle can paint? its not made for canvas or something?
also, did you use the roll and tip method?
tashasdaddy
for the top, just plain old rattle can rustoleum. i have used the gray on dirty gray boat carpet, to correct oil and fish blood stains.
rtpassini
did you do anything to prep the surface? or did you just clean it.
Bruce San
Thanks T.D.! I'll let you know how it comes out.
