bronxrunner1
Thread starter- Joined
- Apr 10, 2008
- 1
1st problem is does anyone know how far in and in which direction do the seals on the criculator pump go. I removed the old ones replaced them with new ones in the same direction in which i removed them but im still getting a leak out of the weep hole, 2nd problem is im having an overheating problem n i replaced the thermostat, the leakthat it has, im thinking cant be the cause of the overheating due to the fact that the motor is running for only 10 min b4 overheating begins, can anyone help the motor is a 1988 mercruiser 170 alpha 1. thanks
