Timberwolf17044
- Mar 20, 2011
- 53
I recently aquired a little pet
A Starcraft Mariner V 14 with a Johnson 30 HP outboard, remote controls. Upon beginning my inspections I found a leaking diaphragm in the fuel pump so I bought and installed a rebuild kit for the pump. I also tore down the carb and cleaned it thouroughly and could find nothing out of sorts there. The unit however still seems to run a little rough so I'm looking for some guru assistance out there with basic setup advice.
#1 What is the proper idle speed?
#2 The carb only has a low speed rich lean adjustment and I'm wondering where to start the position of that screw? My thoughts tell me 1.25 - 1.50 turns out to start?
#3 Idle speed adjustment I assume is accomplished outside the port side of the motor where the cable connects, there is a bracket with a thumb wheel and it seems that turning the thumb wheel counter clockwise increases idle speed. The problem however is that I am completely out of adjustment on that wheel basically backed out as far as I can go with it.
I can't find any means of a simple adjustment for the linkage which would gain me some means to further adjust the idle as everything else is tied together. I'm attaching some pictures of the throttle cable connections and some of the carb. Throttle position in the pictures is low idle. You can see in one of the pics some marks that I was thinking should be lined up with linkage coming up from the carb. Sorry I don't know all the technical terms. I'm sure I am not providing all the information needed but hopefully this is a good start and I can get this puppy running smooth by Sunday. We are expecting 50 degree weather and I'd love to be able to take this out for a test run on the nearby river. Last but not least..
Model: J30ELCUB
Serial: E6251752
Thank you in advance to all who help.
Model: J30ELCUB
Serial: E6251752
