Re: Roller Rocker arms
The whole goal of roller rockers is to minimize friction, and to open and close the valves quicker after holding the valves open longer. Because the duration of a roller cam is completely different than a flat tappet cam, the torque requirements of a very low rpm "tractor engine" will not be met.
Roller tappets will not work well in this marine application.
I have a 3.7 engine, and am familiar with its limitations. There's really not much you can do to improve performance. Just take care of what you've got, and be satisfied that it's economical on fuel.
I just wonder why no one's ever come up with a nitreous system for marine use to get a boat "on plane" instantly? All 4 cylinder I/O engines are so weak coming out of the hole.
