I had my boat in at a repair shop and the mechanic told me that I am needing a master control switch for the motor. What happens is, the engine fires and runs but when it starts to get a little warm after 15 - 20 min. of running it just dies. Will not start. It will turn over but will not start. After you sit for 15-20 minutes the boat will fire back up and run again. I have no knowledge about motors but I am very mechanically inclined. What would your suggestion be? This is a 1992 Force 150 outboard. I have been out of the water with this thing for over 2 years trying to find someone with some knowledge on how to get this repaired for a reasonable cost. Don't really want to go spend $12,000 on a newer motor when this one has good compression and everything seems to run okay when it does run.
