Re: restoring a 1966 5hp johnson
Very nice work Sahara. With your skills, might as well pull it apart and inspect the insides...then decide if you want to hone it. If you don't want to mess with sandblasting, plain old EZ Off oven cleaner (yellow can) will take the factory paint/primer off down to bare metal. Reprime with a self-etching primer and then your choice of color and clear coat paint...but make sure the brands are the same. Mixing brands can mean mixing chemistry and that can lead to bubbling/crazing that means starting over again. I like the Duplicolor stuff...you can see some results at acmeoutboards.com. Good luck with your project...you are definitely on the right track.
