oops!
Thread starter- Joined
- Oct 18, 2007
- 12,932
soooo....your fiberglassing your stringers...floor or transom....the work is allmost done...and you have a little resin left over in your tray or bucket.....
so you think just smear the rest on.....cant hurt...the more resin the better ...right.....
wrong.....
rule of thumb is.....saturate the glass totally...no more ...no less
not enough resin and the glass job will be weak and the glass strands will be prone to break.....
too much...and it becomes like peanut brittle
this is a pic of some left over resin in a small bucket that hardened
nice 1/4 inch thick perfect plate size
this is what happened when i applied pressure with just my bare hands
the thing shattered like peanut brittle.....
if glassed properly you can hit a section of two or three layers of thin glass with a hammer and it will barely dent it....fiberglass can be as strong as steel if it is done correctly.....
remember the rule of thumb....saturate the glass totally...no more..no less
happy boating
oops
wrong.....
happy boating
oops
