apollo5646
Thread starter- Joined
- Aug 16, 2009
- 28
Hello all, well I decided to replace the rotted floor in my boat since we have had 80 here in Michigan which is just unheard off in March. Well I got most of the floor out and of course most the two stringers are rotted to a point, I debated for a long time on weather to try to take the stringers out and replace them but I'm apprehensive for two reasons, One I'm not good with fiberglass and second I don't have the means to pull the engine and I'm not sure if I would have to yank the engine to replace them. I'm not planning on having the boat for more then 5 years more so I had weigh the cost benefit life of the boat etc to decide to just work around it. I did cut the worse of the rotted stringers out and will replace those section and also injected a bunch or git-rot to help. Now my question is what to do with all the foam that is under the decking. I'm sure that its water logged could I rip out and just for go it or does need to be in there for some reason? Could I just rip it out and an leave the space open? Is there structural properties and necessity to the foam or what? What is my best coarse of action here? Also I'm want to use treated 3/4 ply for the new deck. Do I need to do anything special to make the fiberglass stick to it? Will I run into adherence problems with using it or is there a special resin that i have to use with treated wood? Thanks for all the help!!
