Replacing propeller on 3.0 lx alpha drive
REDWOOD22
I bought my first boat 3 weeks ago & my wife & I are trying to learn the ropes. I bought a 1995 VIP Vision 1760 with 3.0 LX engine with lh engine rotation. We trashed a propeller loading the boat and I need to replace it. The propeller on it was a Solas 14.5 x 19. I want to replace it with a reasonably priced but decent propeller since we may trash another before we get this thing figured out. We primarily will be using the boat to pull some of our 6 kids on tubes & skis. Should I replace it with the Solas again? Will I need more to replace it than comes in the box. A local marine dealer had a 14.5 x 18 prop for $160 but said I will need another $40 box of stuff to put it on. I went home to check the engine & found the LH rotation so what he has in stock will not work anyway. any info, tips & site would be greatly appreciated.
fishrdan
Re: Replacing propeller on 3.0 lx alpha drive
Welcome aboard Iboats Redwood. Ask one of the mods to move your threads to the prop forum, you'll get better answers there.
I would double and triple check if you need a LH prop, I find that kind of odd for a single engine boat, especially a 3.0. If the 14.5x19 prop ran well, I would replace it with the same. Solas is a good brand and I'd go back with it, they are available here in the Iboats store for about $100. To find the best prop for your boat you will need to know the WOT RPM for the engine with the boat loaded normally, it should be 4400-4800RPM for the 3.0 engine. Though, the 14.5x19 prop seems appropriate. You might not need the extra $40 of stuff, I'm guessing it was a hub kit for the prop they had. Some props need a hub kit, some have the hub permanently installed in the prop.
If you do indeed need a LH prop, I would go shopping on Ebay as the LH props there are pretty darn cheap there. Not many boats use LH props, so a lot of businesses are trying to dump them. I see smoking deals on props all the time on Ebay, turns out they are LH props....
REDWOOD22
THANKS FOR THE HELP. THE "LH" WAS WRIITEN ON THE TOP OF THE ENGINE. I CHECKED THE PROPELLER & IT TURNS CLOCKWISE SO I"M GLAD I POSTED. I'LL CHECK TO SEE IF i CAN FIND ANOTHER SOLAS PROP TO REPLACE THE ONE i HAVE AS IT SEEMED TO WORK WELL FOR ME.
