Replacing impeler
luisdiaz
Hi. Helping a friend with his yamaha. On a yamaha 115 salt water 1996. To replace the water pump gasket. How to take off the plate? Do i need to take out the shaft collard? How.
Thanks
luisdiaz
Re: Replacing impeler
Here is the drawing. The gasket that need to replace is item 29. The plate is 28. The collar 21 is not getting out.
JUSTINTIME
u need to replace the collar usally
i use a pair of pliers and a rag and twist it off
luisdiaz
Seeing the drawing my self, there is something that just don't make sense. Will send a picture of the real thing probably tonight.
Thanks.
JUSTINTIME
i have done 1000's of these trust me
it is a poor design
luisdiaz
Got that, thanks. This is the picture after taken out the impeller (in pieces) What does not make sense is that the part marked with an X was inside the impeller. How do i get it into the new impeller? (grease, force...?) I do not see this part (X) in the break down.
luisdiaz
this is the picture
cousinabe
that looks like part of the old impeller and should have come off with it.
The new impeller has that piece molded in.
cousinabe
wait a minute... you need to take off the collar and spacers to get that off.
remove parts 21, 18, 19, 20, 19.
to remove part 21, tap with a chisel upwards. take note of the order of spacers.
luisdiaz
Thanks a lot to all of you. Very helpfull information. Now everything make sense.
rodbolt
do a forum search here, I have posted the complete,step by step,bolt by bolt procedure.
its for a V4 but all V4 and V6 two strokes from 95 to about 2005 used the same procedure.
at least it will help keep you from asking how to get out the impeller drive key
