newboater75
Thread starter- Joined
- Oct 31, 2006
- 24
Re: Replacing floor,stringers, foam...
I don't think it is a screw-on swim deck, looks to be made into the top.
okay, sounds pretty straight forward... user exterior-grade plywood... coat in resin; do I want to let the resin cure completely before installing? What do you recommend to "bind" the plywood together for the inside of the transom? Resin? if so, would that mean: cut the 1st piece (slightly big), trim to fit, repeat for additional layers, dry-fit... then to set in; do I, coat the inside of the exterior transom glass with resin, coat the 1st piece of ply, put it in, coat the outside (exposed side from the inside of the boat) with resin, then repeat for the additional layers? Then set up the inside "template" plate with wax coating, and clamp it all in? After setting up (i'm guessing 24-48 hours), remove template plate and glass the inside of the transom and the holes that remain open for parts? Is that right?? Or do you put the layers of the transom together before putting them in and "setting" them?
Thanks again for all your detailed assistance... really don't want to muk this up! Would it help if I posted, or linked, pictures of the inner-top of the transom so you can see how it would be to do the job w/out removing/loosening the top?
