replacing disc brakes
fishnbowler
93 Ranger Trail, changing disc brakes hubs rotors. Problem: kit comes with inside bearing 1.38 and outer 1.16. Spindle is 1.38 front to back. size does not stair step ???
Can the spindle be changed on this model or...
dockwrecker
Re: replacing disc brakes
That's the standard stuff and dimensions for the kit you're looking at typical to a #3500 lb axle. Might want to call or email championtrailers.com and see if there's something built for a straight spindle. I've never seen a straight spindle built for brakes at 1-3/8.
fibersport
Never seen replaceable spindles, at least easily changed. You're looking at a new axle to change spindle size. Is there a chance the axle was changed at some point? Dumb question but did you check both sides on the off chance a PO added a spacer or something?
fishnbowler
Thanks. Sad part is I have already purchased the brake kit. I need to find out if the spindle can be changed on this trailer, or if there is such a bearing size of ID 1 3/16, and OD of only 1 13/16. Everything is great except that one bearing, or the spindle size.
dockwrecker
You're better off to change the axle complete. They can be had for the price of spindles alone and can be changed out in about 1/2 hour with basic tools.
fishnbowler
I have a Ranger Trail boat trailer. I have a straight spindle. 1 3/8 front to back. not stepped sizes. Bought new Kodiak kit w/ hub/rotor, calipers etc. outer bearing ID is too small. Wrong brake kit? Took off disc brake assembly (rusted). What kit do I need? Thanks.
