Re: replaced rectifier and it still is not charging.
The power pack could be the problem with my engine mis, is that correct???
I thought about that, but wouldnt there still be 14v coming out of the rectifier?
Also, If i uderstand correctly, the charging system does not kick in until a certain rpm, is it possible that my motor is just not reaching that point... I am running it on muffs in the driveway and did not want to rev it very high to avoid doing any internal damage.
In addition, I do not have a working tach to know what rpm I am at.
1. Yes the pack can be the source of your miss.
2. Regarding rectifier voltages, I am describing the way is should work, not what you are seeing. You should see 14v (or so) (not real critical)...13-15 v when the reg/rect is charging the battery. I look for 14.7 volts when the system is working right. There, I said it. But it can vary with your engine.
3. Your battery could well be not accepting a charge, fooling the reg/rect into thinking it is fully charged, and therefore limiting the output down to 12v.
I don't know at this point. I asked..."Do you have a known good battery?" You aren't trying to do this testing with an external (110v) battery charger hooked up, but just not turned on are you? The circuitry of the external charger may be fouling up the reg/rect if you are.
4. The charging system does NOT kick in at a magic rpm above idle. It will charge at idle; it will charge at WOT. But if the battery does not need a charge, it will not charge. This is unusual, the battery will almost always need a charge. The reg/rect determines whether or not to charge based on the battery voltage, and how much current the battery is absorbing when running. You may see a slight rise in the charging voltage with higher RPMs, but that is what the reg/rect does...it regulates or squelches that higher voltage down to the normal 13-15 volts needed for charging. It is not that critical....we are talking about a boat motor...not some medical device that measures millivolts heartbeat....
13 -15 volts out, maybe rising with increased RPM, not critical...and 18 volts AC in...maybe as much as 25v AC in from the yellows....it really is a wide range of operation. Now, an unregulated system is totally different. It's voltage will rise and fall with engine speed.
Now, when you read, say, 12.5 vdc at the battery, and start it up and read 12.5v again....now we are seeing a problem. That is where the details matter.
