Repainting speedboat hull
smsscuba
I want to repaint my Picton Sprint speedboat, using Penguard HB primer.It says that it cannot be applied over single pack type paints.
Can I safely use a paint stripper to remove the existing paintwork from the hull to expose the grp or is sanding the only way to go?
chargerboy
Re: Repainting speedboat hull
I would only sand personally, somebody with more experience might have tried using strippers before, but I don't think it's healthy for the resin at all.
Bob_VT
What is the hull material? Wood or fiberglass?
You have a number of options.
Paint stripper which is messy and tends to penetrate wood.
Soda blasting does a nice job if it is available.
Consider other types of paint? Some may work and I would even do a test area.
NSBCraig
as long as it's a stripper made for fiberglass they work great.
