Repaint Motor
1983rinker
Re: Repaint Motor
I used Moeller on my outboard and I used the same paint on the cowl that I used on my boat and put it on via the roll and tip method. I ordered new graphics from my local screen printer. I sprayed my prop with the Mercury Phantom Black.
Before,
After,
Nice.
1983rinker
Re: Repaint Motor
rinker....
Do you want to do this unit one time..and one time ONLY ? ( with caviats of cource..)
There IS the RIGHT way ( not fusion or rusto m8 ).
But FIRST that cow should be a different paint then the lower. ...
What is your motor application ? in the drink full for season..or are you pulling it ?
If your full drink then you might want to look at Trilux apps..
Your Cow.. there is the top notch IMron or Awlgrip. .. .. or low ball rattle it..
The time and money will cost you now.... or later... IMO...
YD.
PS. I will tell you Id rather prep and prime a 40' than a chippedoutwheatherdflakingpeaceofdrivefromhellwithtwocoatingsofcrapaintthatIhavetowarrantydrive ... :)
I may full drink it next year.
Yacht Dr.
Re: Repaint Motor
Then all of the rattle can stuff from rusto to Fusion I dont think will work underwater that long...
Trilux system for underwater of drive ?
Awlgrip the cow :) .
YD.
1983rinker
Re: Repaint Motor
YD.
Ok thanks for the info. What the cost you think??
Bob_VT
Yacht Dr.
Re: Repaint Motor
And not counting the Primicon primer !! Ouch is right ..
What would be the alternitive though ? Im open for more suggestions as your are :)
YD.
Yacht Dr.
Re: Repaint Motor
Ive allways used the Primicon with the trilux..
If that what you were asking..
YD.
NSBCraig
Re: Repaint Motor
Moeller and Tempo are both rattle cans but here again ...... they work fine ONLY if you properly prime. Trying to use them over painted surfaces is near worthless........ they adhere to chromate primers and themselves on the second coat.
Ther effectiveness is no better then Fusion paint or Rustoleum.....but some people are hung up on the color match ability
Proper prep and priming has absolutely nothing to do with the fact that the paint does not cover and is more like painting candy then painting something white.
I used their primer so that's not it.:rolleyes:
It is a completely different type of paint then Rustoleum and works completely different. Rustoleum is way more effective and beyond that the color match of Moeller is wrong for my motor (so don't do it for that reason).
This is why I posted to avoid it (covered multiple times on this here forum before by many posters, all of which agree)
1983rinker
Re: Repaint Motor
Hear a update photos of the cow..
1983rinker
Re: Repaint Motor
New photos
Yacht Dr.
Re: Repaint Motor
Good pics..but..what did you use on the cowel ? kinda sorta to update things :) .
1983rinker
Re: Repaint Motor
I used rustoilem on cow. and zinc cromite on lu. I'm not done yet. I got a few more coats to do on all.
ezmobee
Re: Repaint Motor
I can't take it anymore......it's COWL! Now that that's out of the way, did you use Rusto's "Mettallics" paint? I used that on the top deck of my last boat. I had a heck of a time trying to get it gloss up. Kept coming out dull. I ended up clearing it.
1983rinker
Re: Repaint Motor
Yes I did.
ezmobee
Re: Repaint Motor
You'll prolly want to hit it with some clear coat then.
1983rinker
