alumi numb
- Nov 12, 2008
- 299
Re: Removing rusted stainless screws holding a trim strip
what are screws, what do they do?
they are fasteners and in you case are doing a great job of that, a little to good.
phosphoric acid will take care of the rust and nutralize the chemical process.
you may be drinking some right now, cola.
rustmort and picklex are also great ways of dealing with rust and last.
use any of the above products reclean then coat with rustolium "little brush".
clean up the rubber strip, coat with silicon, wipe down then put back on. when i repaint my starcraft islander my answer will be masking tape.
r.g. may be the only one here on the right track.Hi all Around the edge of my grp boat it has an aluminium trim strip. This is held on by LOADS of rusted stainless screws, like one every 5 inches. The heads are no longer any good at all and I would like to find a way to remove the strip without destroying it.
I tried some high quality HSS drill bits, but the the abrasiveness of the rust just ate through them, before I could even get to the steel.
Any ideas?
