paczowski123
Thread starter- Joined
- Mar 20, 2011
- 115
I have a 17ft Bass Boat that as started to get some oxidation on the white bottom. Someone has mentioned using oxalic acid (wood bleach) on the bottom of it then rinsing and waxing to remove the oxidation. Is this the correct method? Also, some oxidation or other foggy looking buildup on the top of the boat where the glitter coat is. My question is can this acide be used on the top coat as well to try and remove that other oxidation? Then follow with wax. Or would something like a polishing compund work as well?
