Lou C
Thread starter- Joined
- Nov 10, 2002
- 14,517
Hello all,
I need to install a new throttle/shift control on my 88 FW H-200 because the old OMC control is getting really sloppy. The side panel has to come off, its is held to the inside lip of the top cap by a series of studs that are screwed into a fastener inside the wood backing. The panel is held to the 'glass by a 3/8th nut screwed onto the threaded stud. The problem that the studs are spinning and the nuts are rusted to the studs. I tried to use an offset box ratcheting wrench to turn the nut but since the studs are spinning in the wood backing panel they won't loosen. I tried holding the studs with a vicegrips but access inside this panel is very difficult. It seems they chose the most difficult possible way to secure these panels. Any ideas from those who have done this before? Some years back I was able to remove the front bow cushions up that are up against the consoles because the access was much easier under the console/dashboard. This job is a lot more difficult....
