Well, I found the transom bad in my 29' carter Safari, the cap is pretty much on for good, and there is no way in hell it will come off. Also the stringers and engine mounts are good so they do not need to come out either. Is there any way to do it other then chiseling it peice by peice? also, should i cut around the stringers, or cut them off an inch or 2 back and then slide a new transom in behind?
here is a pic
here is a pic
