Reinell T1801 Complete Restore
pcmpete
Re: Reinell Foam stringers repair/replace?
I had cracks in the gelcoat where the ski hook was fitted, what a surprise no support bracing was fitted to the inner :rolleyes:
I had enough pre-joined plywood from the transom build to make a brace for the ski hook, plus supports for the two lifting rings on the stern. These (when fitted) should be strong enough to pull a houseboat without flexing/cracking :D
Again, everything wooden is encased with 2 or more coats of resin.
New Ski Hook Brace
New Lifting Rings supports
pcmpete
Transom and Motor Mounts installed
Just an update.
Got the transom fitted. Attached with peanut butter mixture of Poly, 1/4" chopped strand and fumed slica. I have it screwed and clamped from the outside.
Also finished and fitted the motor mounts. Because the stringers are foam I decided to make full length mounts. These where made up of 4x4 lumber with the bottom shaped to fit the hull and peanut buttered in. Then covered with 3/4" plywood.
The swim ladder support was fitted using the same method as the transom.
The foam stringers got damaged during DE-construction. I filled in all dents and chips in the foam with Poly and micro balloon mixture, so when it comes to glassing over the stringers I will get good bonding.
The original setup had no drainage at all, so I added some to the rear of both stringers and both bulkheads. So, no matter where the water gets in, it all should reach the bilge.
I used 3/4" pvc pipe, cut one end into cutting teeth and by hand I was able drill a hole thru the foam, then cut the pipe to suit.
Rear stringer drainage
Front bulkhead drainage
Now I need sand and clean before glassing.
pcmpete
Tank support
Tank support
Here is my solution to fitting the belly fuel tank. It should supply plenty and strength/support to the fuel tank and allow plenty of ventilation around the tank.
The base support is 3/4" plywood and the spacers are 1/2" ply.
pcmpete
Engine Bay
Engine Bay
Finished the construction of the engine bay area, ready to start prep work for tabbing & glassing
ezmobee
Re: Engine Bay
Re: Engine Bay
I'm not a glass guy but your work is looking VERY nice and solid to me. Great job.
pcmpete
Re: Engine Bay
Re: Engine Bay
Thanks ezmobee, it is going slower than I thought, but I am taking my time to do it right so I don't have to do it again (to this hull anyway)
All my bonding, filling and filleting was done using poly resin as the base, so everything should be strong. Only used 3 gallons of resin to get to this stage. :eek: and approx 5 gallons to go. But my local supplier has a special price of $119 for 5 gallons going on now, every bit helps.
Thanks for looking
Friscoboater
Re: Engine Bay
Re: Engine Bay
Looks awesome so far. What thickness of wood did you use for the transom? 3/4?
pcmpete
Re: Engine Bay
Re: Engine Bay
Thanks frisco, I used two pieces of 3/4" bonded with slightly thickened poly and one layer of 1.5oz CSM. The bonding surfaces of the plywood got two coats of resin before I joined them, then the 'new' 1.5" transom got sealed up.
Friscoboater
Re: Engine Bay
Re: Engine Bay
Cool. That is what I used too, but in the picture it looks thinner. Its my eyes I know.
pcmpete
Re: Engine Bay
Re: Engine Bay
The photo is weird, you can see the csm layer at the top of the image clearly, but it does look narrower near the bottom of the image, it must be just the angle I took it at. The CSM layer is close to 1/16" thick.
Yacht Dr.
Re: Engine Bay
Re: Engine Bay
Just wondering....whats all that Green filler you put there ?
Just wondering..
You should probably grind away as much Putty as you can before glassing ( right down to Raw glass ). Thats exluding where your putty is made for Fillits.
YD.
pcmpete
Re: Engine Bay
Re: Engine Bay
Just wondering..
YD.
The green looking filler is poly, fumed slica & microballoons.
I will be sanding before glassing.
Thanks for looking out after me :)
pcmpete
Re: Engine Bay
Re: Engine Bay
I have a wooden rail that goes around the stern / sunpad area. But it is currently a greeny / grey color. I sanded a small part of it to see how well it would come up. The sanded part is now a redish color. What type of wood is this and what best finishing method. I would like to be able to see the grain when finished and be hard wearing.
Thanks
rickryder
Re: Engine Bay
Re: Engine Bay
Nice job on the boat! I like the pvc limber pipes :D
I would think the wood is teak...
pcmpete
Re: Engine Bay
Re: Engine Bay
I have not posted on my thread for a while, too busy working on the boat :)
Finally got all the stringers/bulheads and transom glassed in with one layer of 1.5oz CSM and two layers of 1708.
Before I move on to cutting and fitting the deck I need to check my fuel tank for leaks. There was no sign or smell of leaks before i took it out, but I want to be sure before I fit it and place the new deck on top.
Can the tank be successfully tested if I seal up all pipe fittings and sender hole and submerge the tank into a swimming pool and watch for air bubbles?
The reason I ask is because I have a pool but don't have pressure testing equipment.
Your thoughts iboaters please
pcmpete
Bow Deck
Bow Deck
Just an update, I decided to go ahead and cut out the bow deck to allow full access to the stringers and main deck. It is a small price to pay, due to the fact that I wanted to do good reglassing on the stringers.
Here is my inboard resin mixing station. I got tried to of climbing in and out of the boat in 100+ degree garage. Complete with mixing chart.
pcmpete
Transom conversion template
He is the transom conversion template I made from door skin.
parrisw
Ensign
Re: Transom conversion template
Nice work. I like the template.
pcmpete
Testing the Fuel Tank
Before I fitted my deck I started working on the fuel tank, cleaning it, fitting new sender unit and pressure testing. Unfortunitely my tank has a leak in it. Now I have to either spend over $500 for a custom made one, or try and fit a smaller plastic one, or try and fix the one I have:
