Rebuilding my floor
Ngilk9
I’m looking for some help / pointers on rebuilding the floor in my 68 v-142 any help is appreciated
tpenfield
:welcome:
After you have a few posts, you can post some pictures. Look for the picture posting instructions in the 'stickies' at the top of the forum.
First pointer, is that seldom does anyone replace just the floor. Usually, the structure that is under the floor needs to be replaced too. Can you tell us more about the boat, and post some pictures when you can?
Ngilk9
It’s a 1968 Glastron skiflite v-142 I’m replacing the floor because the back 3 feet were rotten as well as the last port to starboard stringer it was not coated in fiberglass I just got the floor out late last night so I will b doing a core test today on the stringers an transom to see if they are any good but the stringers held up to me standing on them
kcon
Unfortunately, 9/10 times if your deck is rotten so are your stringers, bulkheads, and transom. Holding up your weight isn't quite the same as taking on the weight of the hull, motor, gear, and 3-6 people on the water, anyway I'm thinking that core sample might unfortunately show you need a complete gut, and stringer/transom job as well. My boats transom (unbeknownst to me) was 100% rotten, and it still held up to rough use on the water at full weight capacity, I wouldn't have known how dangerous is was until I opened it up.
Fortunately you're on the most helpful and informative forum for boat restorations! Looking forward to pictures.
ceasefire49Z
use goop coat it or 1708 withe epoxy resin. i used the goop coat it. its made from kevlar,graphite and ceramics. paint it on thick and hard as a rock. did the whole floor.
Woodonglass
You don't use 1708 with epoxy and the Goop Coat-It product is a bit pricey to be doing an entire deck with it. Lots better options out there once you KNOW for sure the extent of your rebuild.
Ngilk9
Well strange news stringers are perfectly fine transom however has a few rotten spots below the floor line but when I drilled into it I hit a hollow cavity behind the wood of the transom is that normal or did it delaminate from the shell?
chevymaher
Wood may just be gone in that spot. Mine had a 3 inch wide by foot long section no wood in there at all. No rotten just water.
