FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Re: Quick question about after using your outboard
No need to drain the float bowls (run dry) till your done for winter.
And even then I dont see why, if you use a stabilizer.
Do you run in salt or brackish water? if no then no real need to flush every time either unless you think you are getting sand or something in it.
Running the bowls dry it can cause scoring in the cylinders.It easier to fix a gummy carb than to hone a cylinder.
Use a stabilizer and an Ethanol stabilizer.
2-3 weeks is no time at all.Months is a different thing.J
