Hey everyone,
I'll be doing an end of season oil change in the next few weeks, and I'm looking for some tips on how to make this as fast and easy as possible. I've read about the quick oil drain hose that's sometimes attached to the drain plug of the boat. No such hose is attached to my plug, but I found this:
Is this that hose? Sure looks like it to me, as it is connected directly to the oil sump. How much of a PITA would it be to get this thing down and through the drain plug? I think it's what's known as a garboard plug which appears to be smaller in diameter than the more traditional style, will it fit? Trying to avoid purchasing an oil change pump!
Also it appears that the oil filter is mounted in a very inconvenient location; right behind some water hoses. Any tricks to avoid dumping lots of oil in the bilge when changing it? Also, has anyone done a remote oil filter mount, like maybe relocating it to the drive lube monitor bracket?
Thanks!
Thanks!
