Quick fix for blow by?
buckwacker
To get us through another season, is there a quick fix for blow by?
Does anyone know of a good addative or trick to decrease blow by?
Don S
Re: Quick fix for blow by?
A new long block is the quickest fix.
Those products are designed to move your money from your pocket to the sellers pocket. it doesn't help the engine at all.
JJJ
Depends on the reason for your blow by. I've use Rislone for sticky rings, and Restore for worn cylinders - both help to a small degree.
Oshkosh1
Ensign
NEVER NEVER NEVER use EngineRestore...or ANY product which contains solid particulates.
So called "snake oils" do nothing but lighten your wallet to the tune of the purchase price, products like this are worse because they can actually DAMAGE your engine...especially the fine passages found in engines with Variable Valve Timing systems.
Ayuh,... Welcome Aboard,... There's only 2 cures for blow-by,....
Either just don't start it, or Replace the motor...
riptorn
I thought all engines have a blow by. What is a PCV for?
a1nowell
Maybe! Just MAYBE!
You would have to trailer your boat to a shop that sells BG Products. BG has some absolute miracle products that MAY be able to get you 1 more season. It requires their products and their equipment to make it work. Go to: www.bgfindashop.com and put in your zip code.
Larry
riptorn
Boat engines don't have PCV valves....
Chris.........
EDIT: and no, that's not a tautology. The 'V' in PCV is for ventilation, not valve.
Ya I didn't think so because of the fancy fangled air filters on them. I take it's just a hose from the rocker cover to the air filter because of the constant smoke coming out to the air filter.
JJJ
He didn't say what engine he has, though I doubt very very much it has VVT technology. If it is an old engine that is already shot, how much damage can you do to it. Besides I have yet to see any engine (older) damaged by Restore or a similar product. Granted, it doesn't always help but that is a far cry from causing damage.
It sounds as if he just wants one more year before rebuilding/replacing/or getting rid of the boat.
