mikezohsix
Thread starter- Joined
- Oct 26, 2009
- 111
I'm at the point where I'm going to be sealing up my project Grumman.
http://forums.iboats.com/showthread.php?t=362705
Here's a pic of a typical spot in my hull...
How do you seal the rivets that go thu something on the inside of the hull like these ribs? I can clean around the single rivets and seal them, but I don't see what sealing around the rib would do because it could always leak to the inside.
What's the recommended method to clean prior to application inside ?
What's the recommended method to clean outside if that's the place to seal the rivets above?
my seams were under carpet, and there's some adhesive left after powerwashing. Do I have to remove all that or is good enough good enough?
thx
thx
