MTboatguy
- Jul 8, 2010
- 8,988
Well I picked this little 14' Mirrocraft Sportsman up last summer, to take the motor off and put on my 14' fishing boat, got that all converted over to a tiller steer. Now I am sitting here looking at the Mirrocraft again and wondering if I should put it back in the water. I have corresponded with Mirrocraft and they have identified it as a Sportsman model that was rated at 45 hp, great I have 2 Evinrude 40hp big twins, so I want to put one of those on it. Problem is, the boat is a long shaft boat that somebody took a sawzall to and cut the transom down for a short shaft motor, again, not much of a problem, I have short shaft motors. Now my question is, how to approach redoing the transom with its cut down size, to ensure it will still handle the 40hp motor, I am thinking cutting those few inches of the transom wood and aluminum may have weekend the transom wood, so I am going to laminate new marine plywood and build a new one, then configure a cap to go over it.
Any suggestions? on how to make sure it is strong enough for the older heavier 40hp motor?
Thanks for any ideas you might have.
