Problems starting after fuel filter/water separator change
alldodge
Confirmed spark today with a spark tester.
Assuming this was a blue or white spark (3/8 gap) and it repeated this spark several times as engine was cranking
What we know;
Have spark
Fuel pressure is low but available at 30 psi
Remove flame arrestor, dribble a very small amount of gas down the throttle body. Crank motor and answer does it start or try to?
If it does try, get a Noid light and put on injectors when motor is cranking. Does the Noid light flash as motor is cranking?
helix757
What we know;
Have spark
I just purchased a basic code reader, its coming tomorrow. I will circle back with any codes it throws.
helix757
One thing that I did notice last time I was down at the boat is that while cranking, the Tach goes crazy. Not sure if that is relevant
Scott06
Disconnect it to test bad tach can kill the ignition
Had a similar post on the GTO forum I frequent where one of the guys installed a Progression Ignition distributor (electronic can change timing curve on an ap), during cranking his tach was going nuts and no spark. turned out he was getting EMF from a failing starter. Progression sent him a new dizzy same results , on a hunch he replaced the starter and everything worked... not saying thats whats happening to you but had everyone stumped for a month or two
