Assuming this was a blue or white spark (3/8 gap) and it repeated this spark several times as engine was cranking
What we know;
Have spark
Fuel pressure is low but available at 30 psi
Remove flame arrestor, dribble a very small amount of gas down the throttle body. Crank motor and answer does it start or try to?
If it does try, get a Noid light and put on injectors when motor is cranking. Does the Noid light flash as motor is cranking?
