Power loose at plane out
basstoy7
I have a 2010 Yamaha SHO VF225FL, starts fine, idles good but when I try to plane out within a few seconds power loose will occur. After several attempts my boat will plane out and run fine. If I drop out of plane and immediately try to plane out again - no issues. If I shut down or idle for a short time the plane out issue will return. Any idea what the problem might be?
99yam40
VST not staying full while motor is at low RPM
above a certain RPM the lift pumps run all of the time,
low RPM it turns on and off.
pressure relief /recyle valve sticking open might cause that
sucking air maybe
basstoy7
sucking air maybe
Thanks 99yam40! Replaced the relief valve in the VST, everything seems fine now. Will know for sure after this weekend.
