Re: Please help, need some advice, small deck repair.
Ok, I got a little deeper into this last night, took some pics but don't have them with me now, will post them soon. Here is my revised theory:
This boat did not rot from the bottom up. I think it was parked outside, on a slope, starboard side being downhill, many years ago. Everything is very dry, leading me to believe it happened before the previous owner. The rainwater sat on the starboard side, and toward the rear and seeped in through the seat screw holes. This reulted in a 1-2 ft. radius of bad decking.
The CRAZY part of this is that someone TRIED to repair it in this place once before, TRIED being the key word. The 1 foot square patch consisted of 4 STRIPS OF WOOD! They were all white wood, and none of them covered with resin. Over the top they were smeared with some goofy kind of caulk, no fiberglass, no resin.
The boat however must have stayed dry since the repair, because none of that new wood was rotten, even though it was unprotected. The "bad spot" I found was right next to that "repair". So out with the bad spot, out with the bad "repair", and my resin and fiberglass should be here today or tomorrow. My patch is now going to be about 18" x 28" or so.
This is a very shallow boat, there is only about 2 inches of space between the hull and the deck in this bad spot, Tapering to maybe 4-5 inches at the first stringer. There's only about 8-10 inches between the deck and the hull at the ski locker. The stringers look all good, except for the last foot (rear) of one of them, looks like they nailed the repair board to it, puncturing the fiberglass and allowing water in. So I'll have to decide what to do with that one.
Pictures may come tomorrow...
