I'll try to make this quick and concise as to not waste everyone's time, two comments first:
1. Yes, I'm brand new to this and don't know what I'm doing, except for what I've read on this forum
2. I know that some of you will want to steer me in the direction of ripping the entire floor out and doing a restore. I will not consider this because I have not spent much money on the boat, and need it to just "work fine" (not perfect) for a few years (not forever).
I have a small (less than 1 ft. square) soft spot in my deck. (1982 Procraft 16 ft. boat) The rest of the floor is rock solid. I have chopped a portion of the soft part out, big enough to get my hand and flashlight in. What I found is:
1. The stringers are solid.
2. Everything is bone dry (including the foam), the plywood is dry and "flaky" in that spot.
Based on my reading, here is my picture of what needs to be done, correct me if I'm wrong on the steps or the order of them:
1. I need to cut out a sqare of plywood, just beyond the soft part.
2. I need to cut a new square of plywood, coat the bottom of it with some resin, poly, epoxy, etc., whatever I decide to use, and install it.
3. I need to install fiberglass mesh on TOP of the plywood, and then coat the top with the same resin stuff.
If these steps are correct and I'm not missing anything, here are my main questions:
1. Should I used treated plywood? Would it hurt?
2. How should I attach the plywood, glue it to the stringers or can I screw it to them?
3. How wide are stringers usually, so I know how to cut the square. Is it usually a 2x10 or something (1 1/2 inches wide)? (I can only see one side, if I cut too far, there's no going back) Should I be safe and assume 3/4 inch is center?
Should I overlap the fiberglass mesh, if so, how much? Does it get fastened in any other way besides the resin?
4. Anything special around the seam of new/old plywood, like caulk? Or does the mesh / resin do the trick?
5. Anything else I need to know, being that I just made a fool of myself?
Thank you very much in advance for your time!!!
