pivot tube o-rings penta 275
MNfuncpl
Is there an easy way to change the o-rings and seal on the steering pivot tube in the middle housing on a 275 out drive? Hows this bugger come apart with the fewest headaches? Thanks.
Don S
Re: pivot tube o-rings penta 275
There are only 2. The upper one is the seal under the water hose connector. The lower one is accessed by removing the lower unit.
MNfuncpl
Thanks Don. I was hoping there was a way to get the lower one in without removing the lower unit.Also the parts diagram showed a seal at the bottom of the tube, I ordered it, is it necessary?
Don S
You actually need 3 orings, here is a picture with the part numbers. Items 2 & 3 usually stay in the intermediate housing. You'll see when you get it apart.
MNfuncpl
The top seal looks like it has an o ring built into it and it has a small tear in it. This is ware I saw water coming out when I pressurized the system with a garden hose.
Don S
Then replace it.
