GunHoInc
- Mar 26, 2009
- 71
Re: Over Heating and Confused..
Right now, after I determine if I have the right gaskets or not. I'm testing it tomarow, and checking the temps with a laser temp gun. If there's still a problem then I think all that could be left is the empeller. Yes when they put a new one on they didn't change the housing. This is because, when I bought the boat, the seller gave me an empeller kit that didn't have the housing. But if I have to go through it again, I'm buying a complete kit.
So by the pick above, do I have the correct gaskets??
dAvE
What was replaced when they did your impeller in the drive? I've seen more than one gen I alpha or pre that had this type of problem because the lower housing was not changed on an impeller job when it was damaged. The plastic on the lower hsg directly around the shaft melts slightly and has a rolled over looking lip into the water passage. If this surface is not perfect looking with no "lip" around it it won't seal well with the gasket between it and and the SS plate under the impeller.
I can't count the number of problems like this I've seen from a "bad" impeller job. I've seen it from customers, other shops, and even guys at my shop.
Just because it's already been changed doesn't mean it was done correctly.
James
dAvE
