oil intake adjustment
onebassdoug
Had my 1976 115hp evinrude rebuilt a while ago. Person said they set it fat so it wouldn't lean out again. I believe he set it too fat, how do I readjust it to factory specs
Explain why you mention----" oil intake adjustment " on this motor ?-----You would have to replace the carburetor jets.----Fairly easy to do.----Your location ?
flyingscott
Are you sure he did not just ask extra oil in the fuel? Not uncommon to do in a rebuilt motor. Once that is used up you mix the new fuel at 50-1.
???----There is no ----Injection system ----on a 1976 2 stroke model -----Need a model # of this motor !-----Gas and oil are mixed at 50:1 on this engine.
That was never installed at the factory.----Retrofitted by a previous owner.
