Oil in water this normal or bad?
gazelle
All
I have a 97 force 90 hp. The boat is pretty new to me so I do not know what is normal and am looking for advise. Two weeks ago I hit a rock and damaged the prop. I have replaced the prop and started the boat for the first time in two weeks. The engine smoked a little more than normal on start up but I figure that is simply from sitting unused for two weeks. While sitting in the slip and watching the motor idol I noticed some oil spots surfacing to the top of the water. These spots come up about pin hole size and expand to about a quarter inch. I know that since it is a 2 stroke that some oil will come out the exhaust. The problem is that last night is the first time I have seen the engine run on glass like water. All the other times I have been out there has been a lot of chop due to traffic. So I am curious to if the oil drops have always been surfacing but because of the chop I have never noticed or if I damaged something else when I broke the aluminum prop on the rock. Am I just being paranoid and noticing things more? I have not driven the boat yet just incase. I should also note that with the engine off no oil surfaces, it only happens when it is running hence why I figure it is just the oil in the exhaust but I wanted to be sure. It is not a ton of oil, I would say 50 droplets while running the engine for 2 minutes in idol.
Thanks for helping me set my mind at ease or for telling me I may have other problems.
12Footer
Re: Oil in water this normal or bad?
That's normal to see those baby slicks, and yes, you probably would never see them in chop.This is why manufactures are getting away from 2-strokes. That is the good news.....
But any time You hit something,or run aground, you should inspect the L/U condition by draining and refilling the L/U, (using new plug seals of course), looking for anything that isn't black or translucent oil -- and by rotating the prop by hand to look for wobble,which would indicate a bent prop shaft.
