Ohm specs
Cup420
2003 Yamaha 50hp 4stroke... Looking for the ohm and k-ohm specs. Struggling to find this information and need to test.
dingbat
Ohm testing a coil isn't a reliable means to measure the performance of a coil.
I've had more bad coils test good more time than I can count. The only true measure of performance is to test the output with a spark tester.
Cup420
Tested...ive got good spark
Cup420
What is the motor doing or not doing?
I figured out the problem...its the carbs. Just waiting on o-rings to rebuild. Most of my jets were clogged, but i'm still trying to figure that one out, because I just rebuilt these carbs last year, and i've only used ethanol free. Since i've owned the boat
dingbat
There is no magic bullet….it wasn’t the fuel that caused the problem, it was/is your dirty /neglected fuel system.
E10 is a great fuel system cleaner. Problem being, it flushes all the $rap in the fuel system out into the carbs unless you have a proper (10 micron) filter in place.
Putting E0 fuel in a dirty fuel system results in the same dirty carbs as E10.
